Export MS Chromatogram
The dialog for exporting the MS data is invoked using the File - Export - Export Chromatogram… menu command.
Export MS Chromatogram dialog
Chromatogram
Displays the name of the chromatogram that will be exported.
Export to File
Allows to define the file name of the chromatogram export, including it's path. If no value is selected, the exported file will be named according to the original chromatogram.
File Format
Defines the file format to which the chromatogram will be exported. Clarity supports the export to AIA (cdf), mzXML, MzML and mzData formats.
Compression
Sets whether the data will be compressed during the export to mzML and mzXML formats.
Precision
Sets the data precision during the export. Clarity and a range of other software is 32bit applications.
If you enable the Compression or 64bit Precision, other programs may not be able to import the file if they don't support it.
The header of the exported file will contain information provided by the control module - the type of the ionization, number of ion sources etc. To check the information before exporting, the user may use the Show MS Conditions… button on the Measurement Conditions - Instrument tab of the MS Chromatogram window, which will open the MS Measurement Conditions dialog.
