ISO 6976-16
Compression Factor
where the summation is taken over all N components of the mixture and:
Z(t2,p2) is the compression factor at metering temperature t2 and metering pressure p2
p0 is the atmospheric pressure (101.325 kPa)
p2 is the metering pressure
xj is the mole fraction of component j
s(t2,p0) is the summation factor for component j at metering temperature t2 and atmospheric pressure p0
Mean Molecular Weight
M is the mean molecular weight
Mj is the molar mass of component j
Gross Calorific Value
- Molar basis (real gas property is calculated as ideal)
(Hc)0G(t1) is the ideal molar gross calorific value of the mixture at combustion temperature t1
[(Hc)0G]j(t1) is the ideal molar gross calorific value of the component j at combustion temperature t1
- Mass basis (real gas property is calculated as ideal)
where:
(Hm)0G(t1) is the ideal mass gross calorific value of the mixture at combustion temperature t1
- Volumetric basis - ideal gas
where:
(Hv)0G(t1;t2,p2) is the ideal volumetric gross calorific value of the mixture at combustion temperature t1
R is the molar gas constant
T2 is the absolute metering temperature in kelvins
- Volumetric basis - real gas
where:
(Hv)G(t1;t2,p2) is the real volumetric gross calorific value of the mixture at combustion temperature t1
Net Calorific Value
(Hc)0N(t1) is the ideal molar net calorific value of the mixture at combustion temperature t1
bj is the hydrogen index of component j
L0(t1) is the standard enthalpy of vaporization of water at combustion temperature t1
where:
(Hm)0N(t1) is the ideal mass net calorific value of the mixture at combustion temperature t1
where:
(Hv)0N(t1;t2,p2) is the ideal volumetric net calorific value of the mixture at combustion temperature t1
where:
(Hv)N(t1;t2,p2) is the real volumetric net calorific value of the mixture at combustion temperature t1
Relative Density
- Ideal gas
where:
G0 is the relative density of the ideal gas
Mair is the molar mass of dry air of standard composition (28.96546 kg·kmol-1)
- Real gas
where:
G(t2,p2) is the relative density of the real gas at t2 and p2
Z(t2,p2) is the compression factor of the gas mixture at t2 and p2
Zair(t2,p2) is the compression factor of dry air of standard composition at t2 and p2 calculated as:
where Zair(t2,p0) is the compression factor of the dry air of standard composition at t2 and p0
Density
- Ideal gas
where:
D0(t2,p2) is the density of the ideal gas at t2 and p2
- Real gas
where:
D(t2,p2) is the density of the real gas at t2 and p2
Z(t2,p2) is the compressibility factor of the gas mixture at t2 and p2
Wobbe Index (Gross and Net)
- Ideal gas
where:
W0G/N(t1;t2,p2) is the gross or net Wobbe index of the ideal gas at combustion temperature t1
(Hv)0G/N(t1;t2,p2) is the ideal volumetric gross or net calorific value of the mixture at combustion temperature t1
- Real gas
where:
WG/N(t1;t2,p2) is the gross or net Wobbe index of the real gas at combustion temperature t1
(Hv)G/N(t1;t2,p2) is the real volumetric gross or net calorific value of the mixture at combustion temperature t1
G is the relative density of the real gas
ISO 6976-95
Compression Factor
Zmix is the compression factor
√bj is the summation factor for component j
Superior and Inferior Calorific Value
H0(t1) is the ideal molar calorific value of the mixture (superior or inferior)
Hj0(t1) is the ideal molar calorific value of the component j (superior or inferior)
where:
Ĥ0(t1) is the ideal calorific value on a mass basis of the mixture (superior or inferior)
where:
H̃0[t1,V(t2,p2)] is the ideal calorific value on a volumetric basis, for a combustion temperature t1, of the mixture (superior or inferior), metered at a temperature t2 and pressure p2
T2 is the absolute temperature in kelvins
where:
Zmix(t2,p2) is the compression factor at the metering reference conditions
Relative Density
- Ideal gas
d0 is the relative density of the ideal gas
Mj is the molar mass of dry air of standard composition
- Real gas
d is the relative density of the real gas
Zmix is the compression factor of the gas mixture
Zair is the compression factor of dry air of standard composition
Density
- Ideal gas
ρ0(t,p) is the density of the ideal gas
T is the absolute temperature in kelvins
- Real gas
where:
ρ(t,p) is the density of the real gas
Zmix is the compressibility factor of the gas mixture
Wobbe Index
- Ideal gas
where:
W0[t1,V(t2,p2)] is the Wobbe index of the ideal gas
- Real gas
where:
W[t1,V(t2,p2)] is the Wobbe index of the real gas
d(t2,p2) is the relative density of the real gas
ASTM D 3588-98 and GPA 2172-09
Molar Mass
M is the molar mass of the mixture
Molar Mass Ratio
Gid is the molar mass ratio of the mixture
Gjid is the molar mass ratio of the compound j
Ma is the molar mass of air
Compressibility Factor
Z(T,P) is the compression factor
P is the pressure
√βj is the summation factor for component j
Relative Density
- Ideal gas
where:
did is the relative density of the ideal gas
- Real gas
where:
Z is the compression factor of the gas mixture
Za is the compression factor of dry air
Heating Value
According to ASTM D 3588-98, the real heating value is not given by division of the ideal heating value by the compressibility factor (Z). Real gas heating values differ from the ideal gas values by less than the order of the accuracy of the heating values. Thus, the real heating value is calculated as ideal. Furthermore, according to GPA 2172-09, dividing the ideal volumetric heating value by the compressibility factor provides the energy transferred in an ideal gas reaction per volume of real gas fuel (in Clarity, printed as Ideal Heating Value per Real Gas Volume).
- Molar basis
Hnid is the heating value of the gas mixture on molar basis (gross or net)
Hn,jid is the molar heating value of component j (gross or net)
- Mass basis
Hmid is the heating value of the gas mixture on mass basis (gross or net)
Hm,jid is the heating value per unit mass of component j (gross or net)
- Volumetric basis
HVid is the heating value of the gas mixture on volumetric basis (gross or net)
HV,jid is the heating value per unit volume of component j (gross or net)
ASTM D 2421-02 and D 2598-02
Vapor Pressure
pV is the liquified petroleum (LP) gas vapor pressure of the sample at 37.8 °C
xV,j is the liquid volume percent of component j in the mixture
vpj' is the vapor pressure factor of component j at 37.8 °C
Relative density
d is the relative density of the mixture
sgj' is the relative density of component j at 15.6 °C
Motor Octane Number
MON is the calculated motor octane number of the mixture
monj is the motor octane number of component j
ISO 8973-97 and EN 589+A1
Density
ρ is the density of the mixture at 15 °C
ρj is the density factor of component j in the mixture at 15 °C
Wj' is the mass fraction of component j in the mixture, calculated as:
Mj is the relative molecular mass of component j
Absolute Vapor Pressure
pv is the absolute vapor pressure of the LPG sample
xj is the mole fraction of component j in the mixture
pv,j is the vapor pressure factor of component j
Gauge Vapor Pressure
where:
pve is the gauge vapor pressure
Octane Number
ON is the calculated octane number of the mixture
xj is the molar fraction of component j in the mixture
ponj is the partial octane number of component j
Additional notes
Methane Number
According to KUBESH, John; KING, Steven R.; LISS, William E. Effect of gas composition on octane number of natural gas fuels. SAE Technical Paper, 1992, equation (4):
where:
MN is the calculated methane number of the mixture
ON is the octane number of the mixture
1.624 and 119.1 are the coeficients obtained via regression as described in the Article
Calculation on wet basis
For calculations of gas properties on wet basis according to norms ISO 6976-95, ASTM D 3588-98, and GPA 2172-09, the mole fraction of water in natural gas saturated with water is added to the resulting NGA Amounts. For ASTM D 3588-980 and GPA 2172-09, the base temperature is defined as 60 °F (corresponding to the saturated mole fraction of water equal to 0.01744). In ISO 6976-95, the available metering temperatures are 0, 15, and 20 °C. The mole fractions of water vapor in saturated gas at these temperatures were calculated according to the following equation:
where:
xw(T) is the mole fraction of water vapor in saturated gas at temperature T
patm is the atmospheric pressure (101.325 kPa).
psat(T) is the saturation vapor pressure of water at temperature T, obtained from the NIST database, Saturation water properties, P.J. Linstrom and W.G. Mallard, Eds., NIST Chemistry WebBook, NIST Standard Reference Database Number 69, National Institute of Standards and Technology, Gaithersburg MD, 20899, https://doi.org/10.18434/T4D303, (retrieved February 15, 2024).
