Display
PDA Properties
Invoking the command Display - Properties... or the icon opens the PDA Properties dialog, similar to the Graph Properties dialog. There are two new tabs here - the Wavelength Axis tab (analogous to the Signal Axis tab) and the Chrom&Spectral View tab described here.
PDA Properties - Chrom&Spectral View
Chromatogram View
Show Peak Purity Index
While checked, the peak purity index curve is displayed across whole chromatogram in the Chromatogram View. The curve is located at the top of the graph and has no Y-axis itself.
Show Active Signal
While checked, displays the active signal from the chromatogram (including labels) in the Chromatogram View pane.
Spectrum View
Sets the default normalization for the data on the Spectral View pane. The possible options are At Current Range, At Whole Range, or Off. For more details see also chapter Spectrum
