Edit
A sub-menu of commands for working with clipboard and tables.
Undo | Cancels the last modification made in a table. This can be used repeatedly as the station remembers all changes done in tables from the initial start-up. Each table maintains its own independent list of operations, so the Undo command will be performed according to the command history of the selected table. |
Redo | Cancels the last Undo command. This can be used repeatedly as the station remembers all changes done in tables from the initial start-up. Each table maintains its own independent list of operations, so the redo command will be performed according to the command history of the selected table. |
Copy | Copies the content of the selected cells to clipboard. |
Paste | Pastes the clipboard content to the selected location. If the area is larger than the content, the copied content will fill all the selected cells. This can be used to fill multiple fields with identical content or with several periodically repeating fields. |
| Delete | Deletes the selected fields (Delete). | |
| Select All | Selects all fields of table. |
