Creating and filling your own library
Libraries can be managed either from the menu Library or using the toolbar which is shown below.
PDA library toolbar
- To create a new library, click the New Library
button.
- To open an existing spectral library, click the Open Library
button and choose your desired library.
- Adding a spectrum into a library is done by clicking the Add Spectrum
button, which opens Spectrum Property dialog. There, you can specify the compound name and add an additional comment.
- To add all identified peaks in the chromatogram at once, click the command from the menu Spectrum - Add All Identified Peaks.
Identified peaks are identified and named in the calibration file. Peaks are added into the currently opened library.
- If you have made any changes in the library and you want to keep them, click the Save Library
button.
- To close a library, use the Close Library
button. If you have unsaved changes you will be prompted to either save the changes or discard them.
