Control Module Is Not Installed
This dialog is displayed in case you tried to add a control module to System Configuration which is not installed in Clarity yet. You can find here an information how to install the module. Mostly it is necessary to reinstall Clarity and select the Full installation or select the specific module to install. In other cases, you must contact the control module vendor to obtain it, etc.
Control module is not installed dialog
