Error Opening Project
This error dialog is displayed if there is an error during opening a project, it also allows you to decide, what will Clarity do in this type of the situation.
Select one of the option below and click the OK to perform the action and continue.
Set this option in case the directory with your projects has moved.
Allows to select another project within the projects directory.
Allows to create new project in existing the projects directory.
Repair Directories and Open This Project
Allows to create required subdirectories in the project's directory.
