Control
Send Method Sends method, that is displayed in the Single Analysis dialog on the Method row, to controlled modules, regardless on the setting of the LC/GC/AS method.
Shut Down Function is individual for each device. Detailed description is in a separate manuals for Control modules.
LC Control
  • Stop Flow : Function is individual for each device. Detailed description is in a separate manuals for Control modules.
  • Set Flow… : Command for flushing/purging the pump outside a run.
  • Resume Idle : Resumes back to IDLE state after flushing/purging the pump using the Purge command.
  • Hold : Pauses the execution of the Gradient Table at the actual flow and mobile phase composition. The same flow and composition will be maintained until the Resume button is pressed.
  • Resume : Resumes the execution of the Gradient Table after the Hold button has been pressed.
  • Modify Gradient… : Opens the LC Control Manual Flow dialog allowing to set custom flow and mobile phase composition, disregarding the Gradient Table set in the method.
  • Note:
    Availability of Resume / Hold and Modify Gradient commands depend on the capabilities of pumps used in the gradient. The commands are only available while an analysis is running.
