Export Chromatogram
Exports chromatographic curve into AIA (*.CDF), text (*.TXT), Multidetector text (*.CHR) or EZChrom ASCII (*.ASC) format. Using the command invokes the Export Chromatogram dialog.
Export Chromatogram
Name of the exported chromatogram including its full path. This field serves for informational purposes only and cannot be modified.
Selects one of the available formats for export:
AIA Format (*.CDF) - is one of the standard formats used for exchanging data among various chromatography systems. Multidetector chromatograms will be exported to multiple files, each signal into a separate file distinguished by the name of the detector.
Further information about AIA format can be found for example in following article: Terrance A. Rooney - "STANDARDS FOR CHROMATOGRAPHY DATA SYSTEMS", Today's Chemist at Work, 1998, 7(5), 15-17.
Clarity only exports raw data and basic chromatogram description, no results, method data, calibration data or GLP data are exported into the AIA Format.
Following text formats (Multidetector Text Format (*.CHR), Text Format (*.TXT), EZ Chrom ASCII Format (*.ASC)) will contain a header and exported data in two columns separated by an arbitrary separator (TAB, COMMA, SEMICOLON).
Multidetector Text Format (*.CHR) - will always contain all available signals in a single exported file.
Text Format (*.TXT) - Multi-detector chromatograms will be exported to multiple files, each signal into a separate file distinguished by the name of the detector. Signals generated by the Auxiliary devices can be exported using the .TXT format - Auxiliary Signals will be listed in the combobox.
EZ Chrom ASCII Format (*.ASC) - is a text format used by EZ Chrom software. Comparing to the Text Format the data are exported in one column only (voltage), separator can be <TAB> only and the structure of the header is slightly different.
Selects the signals for export. An individual detector, or all detectors at once can be selected.
Only for AIA and EZChromASCII Format.
Selects the character to be used as data separator.
Only for Multidetector Text Format and Text Format.
Selects the character to be used as decimal separator.
Invokes the Save As dialog in which the name and location of the file into which you wish to export the chromatogram is entered.
If no name is entered, the name of the exported chromatogram is automatically used with the relevant suffix.
You can chose to export Chromatogram using ANSI or Unicode (UTF 8) encoding.
Chromatogram containing unsaved modifications will be saved before exporting.
