Display
The Display menu provides commands for adjusting the appearance of graphs and tables. It includes options for zooming, previewing graphs.
Icon Command Description
  Preview Graph
Displays or hides the preview graph, which appears above the Standard Chromatogram Graph. It always shows the entire chromatogram. When zooming in on the main graph, the Preview Graph highlights the currently visible section, helping with orientation.
The command is also available in the context menu, accessed by right-clicking on the graph area.
Zoom Out Zooms out the current view of the chromatogram. This command can also be triggered by pressing the - key.
Zoom In Zooms in on the current view of the chromatogram. This command can also be triggered by pressing the + key.
Previous Zoom Restores the previous chromatogram cut. (Ctrl + -)
Next Zoom Restores the previous zoom level of the chromatogram. This command can also be triggered using the Ctrl + + shortcut.
Unzoom Resets the zoom and displays the entire chromatogram. This command can also be triggered using the Ctrl + *.
  Tables Up Swaps the placement of the Calibration Summary Table and the Standard Chromatogram Graph. When enabled (default setting), the table appears above the graph. When disabled, the graph moves to the top, and the table is displayed below.
Properties
Opens the Graph Properties dialog, which controls the appearance and display settings of graphs. The specific dialog depends on the active tab:
This command is also available from the context menu, accessed by right-clicking in the graph area.
