Add All
Adds all peaks from the calibration standard to the calibration, whether for a new calibration level or recalibration. Peaks are identified in the Calibration Summary Table based on retention time and identification windows, while groups are identified by a letter.
- Existing Compound: If a peak/compound already exists in the calibration within the given Search Window, it is identified, and its retention time (if enabled in Calibration Options) and Response are updated for the selected level.
- New Compound: If no matching compound is found, a new entry is created with the name Peak - [Retention time]. This command also adds new compounds to the calibration during a recalibration of a level.
- On All Signals / On Active Signal: Determines whether Responses are added to all signals or only to the active signal in the Calibration Summary Table. Peak identification is shared across all signals.
- Automatic Calibration: All compounds are added to the calibration, and Responses are assigned to the first available empty calibration level, regardless of the selected level. The selected level then automatically switches to the newly filled one.
- Automatic Recalibration: Compounds are recalibrated at the current level, with further adjustments possible later.
- Manual Calibration or Recalibration: The (Re)Calibrate Peak or (Re)Calibrate Group dialog appears for direct data verification and adjustments.
If the calibration standard is hidden (e.g., by resizing the Calibration window or expanding the Compound Summary Table), the Add All command will not be active.
