Installing Clarity
When Windows user accounts are already present on the PC it is recommended to install Clarity from a user account, that will work with it, using the Run as administrator option. When no Windows user accounts have been setup yet it is possible to first install Clarity and then proceed with their creation. Either way it is necessary to check that Windows user access right are set according to chapter Computer User Rights.
The process of installing Clarity to comply with regulated environment rules is as follows:
  • Check whether the package for the Clarity installation is complete, eg. its content matches the packing list.
Do not plug in any hardware yet!
  • Plug in the Clarity installation USB into the computer. Search for removable disc in the file explorer (e.g. My Computer in windows) and run the install.exe file located in the root directory.
  • On the first screen, select the directory for the installation (C:\CLARITY by default), click the Next button, select the directory for data location and click the Next button again.
  • Enter the User code. This code may be found on the back side of the card provided with installation USB or is provided by DataApex by e-mail, click the Next button to continue.
If Clarity wasn't supplied with a user code, it can be run in the Trial mode. In that case, select Enter User Code later option.
  • Set the type of the installation on the next screen (or select the particular installation components in the bottom pane) and click the Next button.
  • Select the name of the folder in the Windows - Start menu where various Clarity shortcuts will be placed. Alternatively, it is possible to prevent the creation of the folder in the Start menu. Then press the Install button.
  • If this is the first installation on given PC, installation of drivers for various hardware needs to be confirmed.
  • Insert the HW key into the USB slot.
At this point it's possible to generate IQ report by starting Clarity using Help - IQ Report command.
  • Connect any other HW.
