Logging of all changes
Every change in the data must be properly logged, along with the reason for the change, so that the reason of the change can be later found. This feature is required by 21 CFR Part 11 and GLP.
Overall, the best way to ensure that every important change is recorded is to log every operation Clarity performs. To check that this is the case, or to set this feature, the Clarity user with the Administrator rights should follow the procedure described in the section SOP - setup logging in Audit Trail
