SOP - Setting the user rights in Windows 11
This SOP was prepared and tested on the computer with Windows 11 Pro operating system (English localization), with the latest updates (as of 31.10.2025) installed.
This process must be performed by a person with Administrator privileges (e.g., an IT specialist). It assumes that the computer is freshly installed with no user accounts other than the administrator one. Clarity is supposed to be already installed.
User accounts setup
User accounts can be either local or domain-based (if the computer is part of a domain).
If the computer is part of a domain, existing domain user accounts can be used directly and it is not necessary to create local user accounts. In such case, include these domain users in a group or assign the required permissions as described below.
If no suitable accounts exist, create local user accounts as described below.
  • Open Computer Management: Right-click the Start menu and select Computer Management. In the left panel, navigate to Local Users and Groups - Users.
  • Computer Management
  • Create a new user account: Right-click the Users item and select New User... from the context menu. Fill in all required fields in the New User dialog, set a password according to your organization’s policy and click the Create button.
  • Create New User
  • Repeat this procedure for each additional user you want to add. Close the New User dialog by clicking Close.
Group configuration and management
Creating a group is recommended when multiple users work with Clarity, as it simplifies permission management. However, it is also possible to assign the required access rights directly to individual user accounts.
If the computer is part of a domain, a domain group may be used instead of a local group. In such case, it is recommended to use a dedicated domain group (e.g., for all Clarity users) and assign permissions to this group.
  • In Computer Management window, navigate to Local Users and Groups - Groups section.
  • Right-click the Group and select New Group... from the context menu and add its description. Then click Add to manage members.
  • Users Group
  • Click Advanced in Select Users dialog. Select User (Advanced) dialog is opened.
  • Click Find Now and select all users you want to add from Search results: list at the bottom of the dialog.
  • You can verify which users are members of the group in the group properties.
Perform the first login
Perform first login for all newly created users. This step is essential — performing it later can compromise the electronic security of Clarity records.
During the first login, the newly created users are automatically added to the Authenticated User group. To ensure proper data protection under GLP, this group must not have access to Clarity subfolders. This is achieved by removing inherited permissions as described in the steps below.
Each user may create a shortcut to Clarity on their desktop for convenient access.
Setting the permissions
  • Log back in as the local Administrator.
  • Locate the Clarity installation directory. If the DataFiles subfolder is elsewhere, verify that it is properly setup using System Directories in Clarity.
  • Right-click on the subfolder Cfg and select the Properties from the context menu. Switch to the Security tab.
  • Cfg Folder Security Properties
  • Select Advanced and window Advanced Security Settings for Cfg opens.
  • Advanced Security Settings - Initial state
  • Click Change permissions button which will invoke new window for settings of permissions. Click Disable inheritance button and new Block inheritance window will be invoked. Click Remove all inherited permissions from this object option which will result in cleared out Permission entry in Advanced Security Settings for Cfg window.
  • Block inheritance
    Advanced Security Settings - No Entry
  • Click the Add button which will invoke new window for settings of the permissions. Click Select a principal to open Select User or Group dialog.
  • Permission Entry
    Select User - Initial
  • Click Advanced... to open advanced dialog view.
  • Select User - Advanced
  • Click Find Now and select the group you created for Clarity users. If you didn't create any, select individual accounts.
  • Click OK in the Select User of Group (Advanced) and Select User of Group dialogs.
  • Select User - Final
  • Click Show advanced permissions. Select the relevant permissions for the user accounts of those who will run Clarity.
  • User Permission Entry
  • Repeat this procedure for Administrator user account and SYSTEM. Both should have all privileges.
  • Administrator Permission Entry
  • Final security settings for Cfg is displayed in image below.
  • Advanced Security Settings for the Cfg Folder
  • If needed, the settings can be reviewed for respective users/group from the Security tab in Cfg Properties window.
  • Repeat this complete procedure for DataFiles folder for user group (all user accounts of users who should run Clarity) and local Administrator user account in exactly the same manner (SYSTEM permissions are not required here).
  • Advanced Security Settings for DataFiles Folder
  • Repeat this complete procedure for Bin folder for user group (all user accounts of users who should run Clarity), local Administrator user account, and SYSTEM in the similar manner. Be careful as permissions setting for users is different (SYSTEM and local administrator both require full control).
  • User Permission Entry for Bin Folder
    Advanced Security Settings for Bin Folder
