Signal out of range indication
Under specific circumstances, it might occur that a portion of a peak is cut at top. This is caused by the signal being out of range of the current detector or A/D converter:
It is possible to indicate that a signal has reached a value out of the detector range via scheduling an event in the Event table. Such event needs to be triggered by the signal reaching a specific value, that is right below the detector maximum.
For that, set the event according to the following steps:
  1. Open the Method Setup and prepare the method as necessary (or open an already existing method).
  2. Switch to the Event Table tab.
  3. Fill in the first row of the table:
    1. Name (e.g., Signal out of range)
    2. Type - Input Run >
    3. Source - your detector or A/D converter
    4. Value - slightly below the maximum range
    5. Output Type and Output - based on your requirements, for example Abort.
Once the entered input value is surpassed, the specified output event is triggered. Suitable output events also include alarm activation, close a contact, etc.
Solvent peaks typically surpass the detector range. Consider the presence of a solvent peak in the sample before setting output events such as Abort, Skip vial, etc.
