Exporting sequence
It is possible to export sequence to other more common formats. Supported formats are Excel Table (*.XLSX and *.XLS suffixes) or Text format (*.txt).
  1. Open the sequence you want to export, then use the File - Export… command to open the Export Sequence Table To dialog.
  2. Select the appropriate folder for saving the exported sequence .
  3. Fill in the name under which the exported sequence will be saved .
  4. Choose the format in which you want to export . For Text format, the ANSI or Unicode encoding are available.
  5. Press the OK button to perform the export .
