Taking control of Clarity Instrument
You may take control of an Instrument where a different user is already logged in. To be able to achieve this, the option Take Control of Locked Instrument has to be enabled in the User Accounts settings for the user who wants to take over.
Setting up the User Right
- Open the User Accounts window by clicking on
or choosing System - User Accounts.
- Check the Take Control of Locked Instrument in the User Access Rights ⓐ part of the dialog for users who should be able to do so.
It is recommended to set one common Desktop File for all users with this option enabled. Otherwise the desktop of the first logged user will be used for all users that take control over the Instrument, until the Instrument is closed again. It is also recommended to set the same Edit... rights for users that plan to take over Instruments (other rights might differ between the users).
Taking Control of Locked Instrument
- Select Instruments - Unlock Instrument 1 from the Main Clarity window or click on the Instrument image ⓑ.
- Choose your User Name ⓒ.
- Enter the password and click OK.
The steps are similar to the standard logging to instrument.
All unsaved changes in files made by the previous user will be discarded.
It is possible to take control of a locked Instrument using the Command line parameters. The user (user=…) and password (p=…) parameters must be included for each command. Althought commands can be run on the locked Instrument this way, the Instrument remains locked.
