How to calculate Peak to Valley Ratio
This chapter describes how to calculate Peak to Valley, which is a ratio of signal height in peak apex and signal height in the end of peak. This ratio is used for e.g., impurity determination.
  1. Open a chromatogram you want to work with and switch to Results tab.
  2. Add a User Column as described in chapter "User Columns".
  3. Fill the Title for the new column - e.g. P/V Ratio .
  4. Uncheck Calculate Total .
  5. Enter "[Height]/([End Value (Signal)]-[End Value])" formula to the Expression field . You can either use items from Columns: list or type it manually.
  6. Close the dialog by clicking OK.
  1. New P/V Ratio column is displayed in the Result Table.
Value is only valid for peaks, where peak end is not on the baseline.
