Clarity Lite Chromatography Software
Clarity Lite provides data acquisition from one chromatograph with an analog output. This simplified and inexpensive solution is suitable for non-regulated environments.
Up to four signals from a single chromatography system (sharing one common timebase) can be acquired. Only one compatible A/D board/converter can be used. The usage of Clarity Lite is limited to non-regulated environments because it does not include functions for 21 CFR Part 11 compliance. Clarity Lite is the ideal replacement for old HPLC/GC integrators and can easily be upgraded to standard Clarity.
The Clarity Lite main window is the control center of the entire process of data acquisition and evaluation. The Information Table displays the processed sample: Name, applied template method, acquisition mode, etc. The Status Line indicates the current state of the analysis: elapsed time and state. The Analysis-processing Diagram provides icons for fast access to each process of the whole procedure.
The Chromatogram window displays the chromatogram and its results. Users can easily edit acquired chromatograms visually, in the graph, or through the Integration table. The Result Tables can be easily customized to display the data you want see exactly in the way you want to see them. The Summary tab displays data from overlaid chromatograms in one table for easy comparison.
The Calibration window has two main screens, a global calibration table and dedicated tabs for each compound (on the screenshot). The compound tabs contain a table with concentration levels matching the response with Amount and a calibration curve. Any point can be temporarily suspended in the graph it is then marked with a circle instead of a cross.
The Sequence table can be easily edited, using the fill down the user can easily compose the sequence with many injections. The status of each row is indicated by the colored symbols.
How to integrate Clarity Lite in your lab?
How to get support for your Clarity Lite software
Whether you have a question about any functionalities of the Clarity Lite software or need to send us your files for inspection, please see the page dedicated to technical support of your software. We respond during the next business day.
Main features
MeasuringSimultaneous data acquisition from up to four signals (detectors) attached to one chromatograph.
IntegrationThere are extensive possibilities for modifying chromatograms. The chromatogram can be changed by entering global parameters or interactively, through the direct graphical modification of the baseline.
OverlaySimultaneously displays a virtually unlimited number of chromatograms and their mathematical modification; for example, mutual deductions or derivations of any order.
CalibrationInternal and external standard calculation methods, calibration of groups of peaks and reference peaks method for better identification.
Automated measuring supportSequence tables for any set of samples with or without an autosampler.
PostrunAutomatically displays, prints, exports and starts other programs after completion of measurement.
Summary result tablesDisplays and prints selected results from all simultaneously displayed chromatograms.
User settingsUser selects parameters for peak display and the specification for axes, including color from an extensive array of colour settings. Text labels and lines, either as part of the area or anchored to a chromatogram, may also be inserted.
User settingsUser selects parameters for peak display and the specification for axes, including color from an extensive array of color settings. Text labels and lines, either as part of the area or anchored to a chromatogram, may also be inserted.
ExportOptional exportation of all results with or without the chromatogram, in various formats, into a file or clipboard.
ImportImports chromatograms or mathematical curves, which have been saved in text or AIA formats, from other programs.
Method and calibration historyEach chromatogram can easily be displayed under the same conditions as when it was printed, exported or saved.
Language Localizations availableUseful for non-English speakers. At the moment, there are French, German, Russian, Spanish and Chinese localization available in single installation package. Simply switch to your preferred language anytime.
 Clarity Lite Chromatography software
Part Number (p/n)C40
Required A/D ConverterColibrick
