Single Analysis dialog
The new fields named K and Alpha and a new Load K & Alpha button emerge in the Single Analysis dialog. The K and Alpha fields enable to enter the Mark-Houwink parameters used for universal calibrations. The default values 14.1 and 0.7 are valid for linear polystyrene in tetrahydrofurane at 25 °C. The Load K & Alpha button enables entering those values from user editable table in the K & Alpha dialog.
If you import chromatograms using the File - Import Chromatogram… menu in the Chromatogram window, values entered in the K and Alpha fields will be saved in the imported chromatograms.
Single Analysis
