Sequence window
In the Sequence window in the GPC mode new columns for entering K and Alpha values are available. The values can also be entered from editable table using the Select K Alpha... command ( icon) available either in local menu (accessible after right mouse click in the table area) or Sequence menu. The GPC Std Type and GPC Std No columns serve for automatic recalibration of GPC calibration during sequence runs. The columns that should be displayed or hidden can be set using the Hide Column(s) and Show Hidden Column(s) commands from local menu. Such feature is the same as in the standard Sequence window.
Sequence window
Only relevant parts of report for the actual mode selected (Standard or GPC) will be printed from the Report Style selected in Sequence.
