View
This is a submenu for setting up the appearance of the main Clarity window. Similar ones can be found in all major Clarity windows.
If the main Clarity window covers any of the dialogs, the workstation will look as if it has not reacted to any of your commands. In this case it is important to shift the main window aside and react to the covered dialog report.
Hide All | Minimizes (hides) all open windows. |
Show All | Displays all open and minimized (hidden) windows. |
Tablet Mode |
Switches Tablet Mode on/off. Tablet Mode represents a special windows layout in Clarity dedicated to simulate one window application. It is designed for devices with small tablet size monitor that enables their control. In default layout, Instrument window is narrower then in standard Clarity and is positioned to the upper left corner of the monitor, other windows are opened one over another and fill the remaining space on the monitor. All windows remain fully resizable and customizable. Default layout can be restored by reactivating the Tablet Mode. Tablet Mode allows use at higher general scales in Windows (up to 200 %) which improves handling of the software and parameters readability. Tablet Mode is not accessible in Clarity Lite. |
Toolbars |
Displays commands for toolbars.
Note: Reset All does not display hidden toolbars. To show them invoke Customize... - Toolbars menu. |
In case you accidentally move the menu bar out of the screen, you can return it back by using the shortcut Alt + V.
