User Code…
Enters, displays and edits the User Code. The user code is the encoded form of the Serial Number of your Clarity station.
The Serial Number (S/N) is a unique number, that is linked to the specific HW key. It can be found on the back of the plastic card provided with the installation USB or in the About dialog in Clarity.
The User Code is saved in the clarity.sno text file in the Clarity installation group (implicitly C:\Clarity\Cfg.
The User Code also defines the number of Clarity Instruments available for measurement and which Control Modules you are allowed to use.
User Code dialog
If you do not enter the User Code (accomplished by hitting Skip in the User Code dialog during the installation), Clarity will be able to run 30 days or 100 starts (whatever comes first) in Trial Mode. Trial Mode is indicated in the header of the main
