Settings
Sub-menu with commands for setting export and post-processing of chromatograms.
Export Data | Opens the Export Data dialog which sets the method of automatic results export. |
User Options… | Sets up Instrument properties. |
Toolbars | Displays commands for toolbars. The command is similar to the View - Toolbars command in the main
Note: Reset All does not display hidden toolbars. To show them invoke Customize... - Toolbars menu. |
In case you accidentally move the menu bar out of the screen, you can return it back by using the shortcut Alt + V.
