Display
This is an entry point to a submenu of commands for displaying chromatograms.
Preview Graph | Displays/hides the orientation graph. | |
Zoom Out | Zooms out the current part of chromatogram. Also invoked by pressing - key on numeric keyboard or by turning mouse wheel clockwise with Ctrl pressed. |
Zoom In | Zooms in the current part of chromatogram. Also invoked by pressing + key on numeric keyboard or by turning mouse wheel counter-clockwise with Ctrl pressed. |
Previous Zoom | Using the ![]() |
Next Zoom | Restores the original cut abandoned by the Previous Zoom command. (Ctrl + + on numeric keyboard ) It can be used repeatedly to go forwards through existing cuts. The station remembers all cuts effected during current session. |
Unzoom | Using the ![]() The original size may not always represent the whole chromatogram. If you have a fixed display range (Range - Fixed) set by the Display - Properties… command on the Time Axis or Signal Axis tabs, the chromatogram will be displayed in this range. Equally, the chromatogram may not be displayed whole if using the Scale Y Mode function from the Signals tab. |
Tables Up | Mutually exchanges the locations of the chromatogram and the tabs with tables so that the tabs with tables are at the top and the graphs are below. | |
Show Balloon Help | Displays balloon help next to the cursor lines when user performs interactive modifications of the chromatogram. This feature can also be switched on/off using the ![]() |
Properties | Controls the displayed graph and chromatogram(s). |
