Preview Graph
Displays/hides an auxiliary graph. The auxiliary graph is designated for displaying the cut-out performed in the main graph. The command can also be found in the local menu invoked by right clicking above the area of the graph. The auxiliary graph is always displayed in its original size.
Auxiliary Graph
If the size of the graph pane part falls below certain dimensions, the auxiliary graph is no longer displayed, regardless of the activatedPreview Graph command. In such a case the graph can again be displayed by shifting the splitter separating the graph from the tables or by enlarging the entire Chromatogram window.
The original size means either the size where the chromatogram fills the entire graph or a fixed size preset by the Range - Fixed commands from the Graph Properties - Signal Axis and Graph Properties - Time Axis dialog.
Work with cut-outs in auxiliary graph
A cut-out is illustrated in the auxiliary graph by a dotted rectangle. A cut-out can be easily created and shifted and its dimensions changed here.
Manipulating preview graph using the mouse cursor
| Action | Effect |
| Creation | Place the cursor in one of the corners of the envisaged cut-out. Click and hold the left mouse button, then draw the cursor diagonally to the opposite corner and release the button. |
| Shifting | Place the cursor inside the illustrated dotted rectangle. The cursor changes to . Click and hold the left mouse button. Shift the cut-out to the required place and release the button. |
| Change of size | Place the cursor on the edge of the cut-out. The cursor changes to , or . Click and hold the left mouse button. Change the size of the cut-out and release the button. |
Manipulating preview graph using the mouse wheel
| Action | Effect |
| Wheel alone | Shifts cut-out of chromatogram up/down |
| Shift + wheel | Shifts cut-out of chromatogram left/right |
| Ctrl + wheel | Enlarges/reduces cut-out of chromatogram |
| Ctrl + Shift + wheel | Enlarges/reduces the cut-out of the chromatogram in the dimension of the Y-axis only. |
Navigation using the mouse wheel will function even when the auxiliary graph is hidden.
or
