Edit
Commands for working with the clipboard and individual tables.
| Icon | Command | Description |
Undo | Cancels the changes done in tables (shortcut Ctrl + Z). |
Redo | Reverts the last Undo command (shortcut Ctrl + Shift + Z). |
Cut | Moves the selected text to the clipboard (shortcut Ctrl + X). |
Copy | Copies the selected text to the clipboard (shortcut Ctrl + C). |
Paste | Pastes the clipboard content to the indicated place (shortcut Ctrl + V). |
| Fill Down |
Copies the content of the current cell to all directly below it or to a selected range of cells in the same column. This command can also be triggered using the Ctrl + F shortcut. Fill Down only works when the selected range consists of consecutive cells in a single column. |
| Fill Series… |
Opens the Fill Series dialog, allowing incremental values to be filled into all cells below the current one or within the selected range. Fill Series can be used in most input fields where values can be freely entered, except for predefined selection fields such as Peak Type, Use ISTD, and Curve Fit Type. |
| Select All | Selects all cells in the table (Ctrl + A). | |
| Restore Default columns | Resets all columns to their default settings. This restores the default column widths, displays only the default visible columns, and hides the rest. | |
| Setup Columns… | Using this command invokes the Setup Columns dialog, where you can set the display of columns. | |
| Hide Column(s) | Hides the selected columns. Columns can be selected by left-clicking on the column header, and multiple columns can be selected by holding the Ctrl key while clicking. | |
| Show Hidden Column(s) | Shows all hidden columns. |
