Setup Columns
Setup Columns dialog is used to customize the columns of the tables in the Calibration, Chromatogram, and Sequence windows.
To access the edit dialog of user columns the user must be authorized to edit methods. See the Edit Method checkbox in the User Accounts dialog.
Setup Columns
Table Properties
This section is not present in the dialog invoked from the Sequence window.
Hides value units in the cells in columns where they were previously shown by the Show Value Units checkbox in the Selected Column(s) Properties section.
Shows the list of all hidden columns.
Shows the list of all displayed columns.
Displays all existing columns by transferring hidden columns from the left Hidden Columns list to the right Shown Columns list.
Shows the selected hidden column(s) by transferring them from the left list to the right list. The displayed columns are added to the Shown Columns list in the fixed order, but may be moved forward/backward via the arrow icons on the right of the Shown Columns list.
Hides the selected displayed column(s) by transferring them from the right to the left list.
Hides all columns by transferring them from the right to the left list.
This section is present only in the dialog invoked from the Chromatogram window.
Opens the Add User Column dialog (for more details see also chapter Add User Column ) to add a new column with user-defined calculation.
Modifies the selected user column.
Deletes the selected user column.
Shows the values with units right in the cell for the selected column. This option is not present in the dialog invoked from the Sequence window.
Applies the default font, specified in the Table Fonts - Default Fonts item of the User Options - General dialog (available from the
Opens the Font dialog, which prescribes the font for the column selected.
Specifies the number of valid digits to be displayed in the column selected.
Specifies the number of decimal places to be displayed in the column selected.
Custom Name
Setup Columns dialog invoked from Sequence window contains additional text field Custom Name to set the name of Analysis User Variables. For more details about User Variables see the chapter "Sequence".
Displays a preview of the results in the selected column.
Restores the default columns and their values
