View
Toolbars Displays commands for toolbars. The command is similar to the Toolbars command in the main Clarity window.
  • Analysis, Signals, Zoom, Axis Range: Hides/shows the respective toolbar.
  • Customize…: Customization of items in the toolbars.
  • Reset All: Resets the menu and toolbars back to their initial state as they were from the initial installation of the Clarity.
  • Note:
    Reset All does not display hidden toolbars. To show them invoke Customize... - Toolbars menu.
Grid Lines Displays/conceals auxiliary grid for easier reading of values in the graph.
Fixed Axes Sets the fixed range axes display. The range of signal axis is determined by entering the lower and upper limit (e.g. 15 - 30mV) both in the analysis and outside of it, the range of the time axis is determined by entering the time range (outside of the analysis) or lower and upper limit (during the analysis - e.g. 0 - 20min).
Floating Axes The range is defined by its size (e.g. ± 20 mV; 5 min) While being displayed, the display will "float" so that the signal always stays in the displayed part of the graph. If the signal exceeds the y-axis range, the graph is moved vertically so the actual signal value will be in the center of the left axis. If the signal reaches end of the time range, the graph is redrawn from beginning.
Context Axes Automatically switches between Fixed Axes and Floating Axes setting according to whether the workstation is measuring the analysis (in the RUNNING state) or is merely monitoring the signal (WAITING state). When measuring, the Fixed Axes display will automatically be used, while when in the WAITING state, the Floating Axes will be used.
Auto Axes For the time axis, automatically switches between Fixed Axes and Floating Axes setting according to whether the workstation is measuring the analysis (in the RUNNING state) or is merely monitoring the signal (WAITING state). When measuring, the Fixed Axes display will automatically be used, while when in the WAITING state, the Floating Axes will be used.
The signal axis behaves the same as when set to Floating Axes while the analysis is not running. While it is running, the range of the signal axis starts at a minimal value and enlarges according to the signal course; thus, the signal is always displayed in the graph and the view is not overly large at any moment of the analysis - the signal always fits in it.
Reset Axes Ranges Sets the default values into all fields of the Axes Ranges dialog.
Set Axes Ranges… Opens the Axes Ranges dialog used for defining the ranges of all signals in the Data Acquisition window, both in the run and outside of the analysis run, including ranges used for auxiliary signals.
Show Signal(s) Switches the display of the Data Acquisition window to showing the detector signals. Only available on the PDA or MS instrument types (requires PDA Extension or MS Extension).
Show MS Spectrum Switches the display of the Data Acquisition window to showing the actual MS spectra. Only available on the MS instrument types (requires MS Extension).
Show PDA Spectrum Switches the display of the Data Acquisition window to showing the actual PDA spectra. Only available on the PDA instrument type (requires PDA Extension).
Show Isoplot Switches the display of the Data Acquisition window to showing the isoplot from the PDA spectra. Only available on the PDA instrument type (requires PDA Extension).
