Running the Sequence measurement
This chapter and the prepared Demo1 project will guide you through Sequence window used for automated measurement.
Sequence operation allows automated measurement of large number (depending on PC and autosampler configurations) of samples using chromatographs equipped with autosamplers. Clarity provides the possibility to select an ACTIVE (start controlled by the station) or PASSIVE (start controlled by the autosampler) sequence.
It is also possible to re-process the already measured sequences in the Batch dialog.
It is not necessary to have the Autosampler (AS) Control module to use the autosampler; start synchronization can be performed even without it. However, the control module can add direct control from Clarity, enabling automated actions such as sending vial positions, injection volumes, etc., all without requiring programming the AS through the instrument panel.
