Link Table
This dialog is analogous to the Link Table dialog of the DHA Extension. However, items in the two Link Tables are saved for each extension separately.
This dialog can be used to edit the Link Table in the NGA Extension. The Link Table is used when you have unresolved compound names in the NGA Amounts. For example, you are using compound names specific to your language, but there is a different name for the same compound in the selected norm. The Link Table allows you to link the different compound names so you can use your custom compound names in calibrations and chromatograms as needed.
After you add some link to the Link Table, you can also add them to the calibration using the drop-down menu in the Calibration window.
Link Table dialog
1st column in the table
Number of the Link Table row.
The compound name in the Calibration that is linked to the one in norm, and thus to be included in the NGA Results.
The compound name as given by the norms (if the name is in multiple norms, only one occurrence is displayed).
Add…
Displays the Add Link dialog for adding a new record to the Link Table.
Remove
Removes the selected record from the Link Table.
OK
Saves settings to the Link Table and exits the dialog.
Cancel
Exits the dialog without saving any changes to the Link Table.
