Panes
The PDA Chromatogram window can display single view or can be split into two or four panes. Each pane can display any of the following views: Isoplot, Chromatogram, Spectral, 3D, Peak Purity, Peak Purity Spectra, Spectral Library, and Spectral Search. The size and position of the panes can be controlled by the commands from the View menu and by holding and dragging sliders between the panes with the mouse. To display any of the views in a particular pane click the right mouse button to display the local menu and select the desired view from the list.
  • As there are more available views than panes, it is not possible to see all the views at once. However all user operations with the hidden view are still enabled (e.g., user can open and work with spectral library even if theSpectral Library View is hidden).
  • Each view can be displayed only in one pane at the same time. Selecting a view that is already displayed in another pane will result in switching the positions of the views. Selecting a view that is not yet displayed will result in hiding the original view and displaying the selected one in the pane.
