Graph Properties - Auxiliary Signal Details tab
This tab lets you set the visibility of the particular Auxiliary Signals, as well as scale their signal axis.
Graph Properties - Auxiliary Signals
Source
Select for which chromatograms the auxiliary signals will be displayed
Note
This option is enabled when Use User Option checkbox on the Gradient & Auxiliary Signals tab is not checked.
Common Settings by Auxiliary Signals Types
Shows/hides specific type of auxiliary signal and sets the auxiliary signal axis range for each type. When the Auto checkbox is checked, the range of the auxiliary signal axis starts at a minimum value and expands according to the auxiliary signal's course. While unchecked, the axis range is fixed on the values entered in the respective From and To columns. Checkbox Show shows/hides respective auxiliary signal type in the graph.
Override Settings for Opened Chromatograms
Overrides the settings for any particular auxiliary signal from currently opened chromatogram only when Use Common checkbox is unchecked. This table contains line for every auxiliary signal available in the opened chromatograms. The settings of axis and show checkbox works the same way as in the table above. If checkbox Use Common is checked, parameters from the Common Settings by Auxiliary Signals Types table will be used instead of overriding.
It is possible to hide the auxiliary signal directly in the Chromatogram window by holding CTRL and left mouse double click on the appropriate signal.
