Edit
Provides access to commands for working with the clipboard and table editing in the Sequence Table. Commands from this menu can also be accessed from the local table menu by right-clicking on the table.
The movement direction of the focus after pressing Enter can be adjusted in User Options.
Icon | Command | Description |
Insert New Line | Inserts a new line ahead of a currently selected one. The inserted line will be filled with the same values as the selected line. |
Line Up | Moves selected rows one position up. Moving can be also easily done using the mouse - left click and hold the mouse on the first column of the Sequence Table (with line numbers), drag the line up to the desired position and release.
Selected lines do not have to form a continuous block. |
Line Down | Moves selected rows one position down. Moving can be also easily done using the mouse - left click and hold the mouse on the first column of the Sequence Table (with line numbers), drag the line down to the desired position and release. |
Undo | Cancels the modifications effected in tables (Ctrl + Z). |
Redo | Countermands the Undo command (Ctrl + Shift + Z). |
Cut | Moves the selected text to the clipboard (Ctrl + X). |
Copy | Copies the selected text to the clipboard (Ctrl + C). |
Paste | Copies the clipboard content to the indicated place (Ctrl + V).
If you are pasting to an area that is larger than the clipboard content, the content will be tiled (Fill function). This is useful if you want to insert a large number of the same fields or several periodically repeating fields into the table. |
Fill Down | Copies the content of current cell to all cells bellow it or to selected range (Ctrl + F). Fill Down is disabled for the End Vial (EV) column or when multiple cells in the same row are selected. | |
Fill Series… | Displays the Fill Series… dialog for filling up incremental values to all cells below it or to selected range. Fill Series is disabled for the End Vial (EV) column, when multiple cells in the same row are selected or when the whole Sequence Table is selected. | |
Delete | Deletes the selected table fields. Deleted fields will be reset to their default values. If you have selected entire lines, the lines will be removed. | |
Mark for Run | Checks the checkbox in the Run column for selected lines. These rows will be processed when the sequence will be run. | |
Clear Run Marks | Unchecks the checkbox in the Run column for selected lines. These rows will not be processed when the sequence will be run. | |
Invert Run Marks | Inverts the marks in the Run column of the Sequence Table. All selected rows with the Run column not checked will be checked (marked for run) and all rows currently checked will be excluded from the run (unchecked). | |
Reset Status | Invoking this command (or using the Ctrl + E shortcut) resets the measured line flags on the selected lines. The command will change the color of Status column fields of all selected rows to green (not measured yet).
The status of all lines will be automatically reset while running a sequence using the Run command. During running analysis the Reset Status command is disabled for all rows. |
Restore Default Columns | Restores the default columns setting (for more details see also chapter Edit) |
Setup Columns… | Opens the Setup Columns dialog for the Sequence Table. | |
Select All | Invoking the command (or using the Ctrl + A shortcut) selects the whole Sequence Table. | |
Remove All | Deletes the entire Sequence Table, only the empty first row will remain. | |
Hide Column(s) | Hides all selected columns. | |
Show Hidden Column(s) | Shows all hidden columns. |
