Linking the calibration to a chromatogram
Analysis Procedure: Step 1 -> Step 2 -> Step 3 -> Step 4 -> Step 5
Any chromatogram can be linked to a calibration file, thus automatically providing calibrated results.
- In the Instrument window use the Chromatogram
icon to open the Chromatogram window.
- Use the Open Chromatogram
icon to open chromatogram data based on the calibration you have just created. Use the SAMPLE_VIAL_6-1.PRM file saved in the default directory. Other files in the directory are uncalibrated as well and they will be used later.
Upon opening the chromatogram, the data are uncalibrated and no information about the names of individual compounds is available; the peaks in the Result Table are just described according to their retention times. To change this, the appropriate calibration should be linked to these data.
- Select the Results tab (it should be opened automatically) and look at the section on the right side of the screen. Use the Set... button in the Calibration File (Peak Table) section to select the calibration file created in the previous section (it should be in the default directory). Any peaks present in the calibration are now identified and the corresponding compound names are shown in the chromatogram.
In case you skipped the process of making your own calibration, please use the DEMO1.CAL instead.
