How to print or export results from the DHA Extension
Print
To print the data from the DHA Extension, open the Report Setup window by clicking the menu File - Report Setup… in the Chromatogram window.
On the left side, select the DHA tab. By checking the Print checkbox, the other controls on that pane are enabled. You can configure what information will be printed by choosing the corresponding options.
Settings from the Report Setup are used in the print output and preview, accessible from the File menu of the Chromatogram window.
You can also use the prepared DHA report style: in the Report Setup window, click Open…, and select the DHA_Results.sty report style.
For more details see also chapter Report Setup (NGA) .
Export
Open the Export Data dialog via the Setting - Export Data… menu of the Instrument window. Check the DHA Results and DHA Group Results checkboxes to include them in the exports. Settings from this window are used in the Single Analysis - Post-run Options tab.
For more details see also chapter Export Data (NGA) .
