Instrument window
  1. Start the Clarity station. The main window will appear.
  2. Open Instrument which is prepared to test the Single Analysis. In Clarity Demo it is Instrument 2. Do so by using the Instrument - Login to Instrument X command or by clicking on its icon. The Login Dialog will open.
  3. Let User field filled with the pre-selected Administrator. In the Select Project: combo-box choose option DEMO2 and press the OK button.
You can also load the desired demo project to the Instrument window by using the Instrument - Project... command, then use the Open... button and select the DEMO2 project. This will load all the necessary files.
You can create your own User accounts from the main Clarity window using the System - User Accounts... command.
The Instrument window will open. Fig "Instrument window" shows the most important icons in the Instrument window. During the tour, we will review all windows belonging to these icons.
Instrument window
