Sequence window
- In the main Clarity window, open the Instrument on which you want to test the functions of Sequence. In Clarity Demo it is Instrument 1. Do so by using the Instrument - Login to Instrument X command or by clicking on its icon. The Login Dialog will open.
- Let User field filled with the pre-selected Administrator. In the Select Project: combo-box choose option DEMO1 and press the OK button.
- Use the Sequence
icon in the Instrument window to open the Sequence window.
The Sequence window
- Look at the Sequence Table. Each row of this table defines one or more analyses, depending on the fields SV (Starting vial), EV (Ending vial) and I/V (Injections per vial) ①. As shown, the first four rows each represent a single measurement (SV and EV is the same, I/V is 1), while row 5 represents eight analyses (SV is 5, EV is 8; thus measuring 4 samples from 4 successive vials and as I/V parameter is 2, each sample vial will be measured twice).
- Also note that in the fields Sample Type and Lvl ②, the first four samples are marked as standards on levels 1-4. Chromatograms measured from those rows will be automatically used for the calibration that is linked to the method.
- The Method Name column ③ sets the method used for measuring the row.
- The Report Style column ④ sets the print style used for reporting.
- In the File Name column ⑤
, the name of the resulting chromatogram file is specified. It is recommended to use variable parameters to form the chromatogram filename, for example %Q means that the file name will use the text from the Sample field. The complete set of available variables can be listed after clicking in the field and selecting the
icon. It is possible to combine several of these variables with plain text or symbols to create a unique file name for each chromatogram.
- To verify the sequence setup, click on the Check Sequence
icon ⑥. The Clarity station will change all symbols at the beginning of the row to green fields (
), meaning the rows are ready, or display an error/warning
message if a problem is detected. The error/warning
message is accompanied with a list of corrections for each case, guiding you on what needs to be fixed before proceeding.
For demonstration purposes only, try to make a mistake and check the sequence once more. For example, check the Print checkbox on the first row. You can see that a warning sign appeared on the corresponding row 1. After pressing the icon, the warning message appears, informing that you are trying to Print the chromatogram with no Report Style selected. Holding the mouse above either field will display the tooltip with the cause of the problem. Set the sequence back to its original state and continue to the next step.
- Start measuring the sequence using the
icon ⑦. The state of the ACTIVE sequence will change to WAITING FOR INJECTION. As soon as the Ready signal from the autosampler is detected, the measurement will start.
Even if the autosampler is not connected, Clarity will get the Ready signal, thus starting the sequence. However, it is not possible to generate separate demo data for each chromatogram, as all chromatograms would be the same. For the demonstration purposes, there are examples of the resulting files in the project folder. You may stop or abort the sequence now or later either from the Data Acquisition window or directly from the Sequence window. Close the Sequence window before proceeding.
- After the first row of the Sequence table is measured, the Instrument will once again switch to the WAITING FOR INJECTION state, and the autosampler will start a new measurement by sending the Ready signal. Stop the sequence from the Data Acquisition window or Sequence window at any time by pressing the Stop
button (single-click means that the currently measured analysis will be finished and the sequence will stop subsequently, after double-clicking, the sequence will stop immediately). All data measured will be saved. Instead of stopping, you can also abort the measurement with the Abort
button (does not produce any chromatogram).
It is possible to edit the sequence even during the measurement. However, if it pauses due to an error, it is necessary to resume the measurement after the error is resolved.
- Already measured rows will change their Status from green field (
) to blue icon with small chromatogram (
). During the measurement, the icon is orange.
- A small triangle will appear in the icon
if a chromatograph is produced by the particular measurement in the row. Left mouse click on the triangle will open the menu where you can open the measured chromatogram(s). You can click on the name of the chromatogram to open it or select option to open all chromatograms in overlay as seen in Fig "Opening chromatograms in overlay"
- On the right side of the Sequence Window you can check at each row whether corresponding chromatogram should be opened, printed or loaded into the calibration window. These columns are part of the so-called Post-run Options.
- In the Sequence, there are many more hidden columns including the rest of the Post-run Options, they can be displayed by right-clicking the sequence table and selecting Setup Columns. In the following dialog move columns that should be displayed to Show Columns list.
