Report Setup - MS
Determines the content and layout of the MS-MS spectra printed from the chromatogram.
The Report Setup - MS section items will only be printed from the MS Chromatogram window.
Report Setup - MS
Print
Allows/disallows the printing of the relevant part. If checked, the symbol will be shown before the tab name and other fields on the tab will become editable.
On New Page
If checked, the relevant part will be printed on a new page.
Chromatograms
Determines which chromatograms should be included in the printout in case more than one is opened. You can choose to include to the report the spectra from all opened chromatograms (All) or just the spectra from the active chromatogram (Active Chromatogram).
Spectrum
Governs whether spectral graphs will be printed. Once enabled, lower level sections of Peaks and Height of Graphs get enabled as well to determine the number and size of spectral graphs. All spectra are printed as they are in the chromatogram, therefore if the chromatogram uses stick spectra, those will be printed.
Peaks
Determines the peaks whose spectra will be printed in the report. The options are to print the spectra for all peaks present in the Result Table (All Peaks), all compounds found in the MS Method (Peaks in MS Method) or only the spectrum of the active peak (Only Active Peak). In case the last option is selected in combination with the selection of All Chromatograms from the Chromatograms section, the spectrum will be printed for each chromatogram if it contains the peak with the same name in the Result Table.
Height of Graphs
If the Fixed checkbox is checked, the chromatogram will be printed with a fixed height instead of the fixed ratio 2:3. The permitted lower height range is 30 mm, the upper height range is not set - the graph will be scaled to the page height if larger than the page itself.
MS Integration Table
After checking the Quant. Signal checkbox, integration tables of quantification signals will be printed, based on selection in combobox. Either all quantification signals or selected (one) quantification signal can be printed. When selected quantification signal is not presented in MS Method Table, following error warning will be shown. Tooltip telling what is wrong, when mouse cursor hovers over the icon, will be shown.
