Report Setup
Tabs: Page Setup - Lab. Header - Report Header - Method - Calibration - Chromatogram - Results - Sequence - SST - MS - Audit & Signatures - PDA - NGA - DHA - Lab. Footer
The Report Setup... command in the PDA Chromatogram window opens the Report Setup dialog on PDA tab.
Report Setup - PDA tab
Allows/disallows the printing of the relevant part. If checked, the symbol will be shown before the tab name and other fields on the tab will become editable.
If checked, the relevant part will be printed on a new page.
Signals
Determines which signals information will be printed when there is more than one. You can choose to include either the method parameters from all signals of all chromatograms (All), all signals from the active chromatogram (Active Chromatogram), or only the parameters from the active signal (Only Active Signal).
Height of Graphs
If the Fixed checkbox is checked, the chromatogram will be printed with a fixed height instead of the fixed ratio 2:3. The lower height limit is 30 mm, and the upper height limit is not set (the graph will be scaled to the page height if larger than the page itself).
PDA Data Plots
Enables the printing of the selected data plots. The given view will be printed if the Isoplot, 3D plot, Spectrum, and/or Chromatogram checkboxes are checked. When the Report Setup dialog is invoked from the PDA Chromatogram window, the Spectrum and Chromatogram views will be printed WYSIWYG (including spectra overlays) instead of whole.
Peak Purity
Enables the printing of Peak Purity View (Graph option) and/or Peak Purity Spectra View (Spectra option), both either for All Peaks or only for Identified Peaks. When the Report Setup dialog is invoked from the PDA Chromatogram window, the All Peaks or Identified Peaks selection will be ignored as there is only one peak active in the PDA Chromatogram window, which will be displayed and printed if the Chromatogram - Display Peak Purity command was invoked previously.
Library Search Results
Enables the printing of Spectral Search View (Table option) and/or Spectral View with the actual spectra overlaid by the spectra gained from the library search (Spectra option). When the Report Setup dialog is invoked from the PDA Chromatogram window, the library search for the peak active in the PDA Chromatogram window will be displayed and printed if the Spectrum - Perform Library Search command was invoked previously.
The spectra will be displayed in the overlaid Spectral View regardless of the Show column checked in the Spectral Search View table (as opposed to the printout of the Spectral View displayed by the Spectrum checkbox from the PDA Data Plots section).
Library
Enables the printing of the Spectral Library View (Table option) and/or the spectra of individual rows in the library (Spectra option).
The Library section items will be printed only from the PDA Chromatogram window.
