HTA HT2x00H Control
The HTA HT2x00H control module enables direct control of the HT2000H, HT2000HT and HT2100H autosamplers and HT2800T autosampler set to headspace mode. The control is performed over LAN.
Direct control means that the autosampler can be completely controlled from the Clarity environment - all autosampler parameters can be sent to the sampler directly from the computer, the sequence table can be planned and edited in the Clarity software and the order of the individual vials is directed by Clarity. Specific methods may be assigned for different vials in the same sequence and particular method used for the given sample will be saved in the resulting chromatogram.
The HT2x00H autosampler control module works with the 01.02 or greater firmware revision. It is recommended to check the user manual of the autosampler for its operating principles and restrictions.
HTA HT2x00H Control | |
Controlled models | HT2000H, HT2000HT, HT2100H, HT2800T (headspace mode) |
Cable | LAN cross cable (p/n SK08) |
