Zebrick USB D/A and D/f Converter
Zebrick is designed for controlling LC pumps that can be driven by frequency or voltage using Clarity chromatography software. Zebrick operates with up to 4 D/A converters, 4 D/f converters and 8 auxiliary logical inputs and outputs.
LC pump control is available as an option to the Clarity sofware. Control can be accomplished using Method Setup - LC Control and LC Monitor dialogs accessible from the Instrument window.
Zebrick is successor to the CB20 D/A and D/f card.
Brief list of features
- Available inputs and outputs
• 4x 16-bit D/A converters
• 4x 28-bit D/f converters
• 8x auxiliary logical inputs and outputs
- Other details
• Powered from the USB port
• Allows mounting on a rack
• Replaces CB20 PCI card
Zebrick | |
Voltage range | -10 V +10 V |
Frequency range | 0 Hz - 100 kHz |
Digital inputs/outputs | 8/8 TTL (5 V) |
PC Interface | USB |
Power source | USB, no external power adapter is required |
Zebrick | |
Part No. | B30 |
Warranty | 3 years |
Related products | Clarity software - Part No. C50 (required) LC Control - Part No. A24 (required) |
Cables included | Part No. KBCB, 2V+2f, length 3m, modification upon request USB cable, Part No. SK10, length 1.8m |
Compatibility
Windows 11 (64-bit) |
Windows 10, 8.1, 7SP1 (all 32 and 64-bit) |
Zebrick | Clarity (from 8.7) | Clarity (from 7.0) |
Compatibility with obsolete operating systems
Windows XPSP3 (32-bit) |
Zebrick | Clarity (from 7.0 to 7.4.1) |
