Spark Alias Control
The Spark Alias control module enables direct control of the Spark Alias autosamplers. The control is performed over the serial line, LAN or USB, depending on the installed communication interface.
Direct control means that the autosampler can be completely controlled from the Clarity environment - all autosampler parameters can be sent to the sampler directly from the computer, the sequence table can be planned and edited in the Clarity software and the order of the individual vials is directed by Clarity. Specific methods may be assigned for different vials in the same sequence and particular method used for the given sample will be saved in the resulting chromatogram.
The Spark Alias autosampler control module also covers the autosampler User Program, however it needs the 1.23 or greater firmware revision of the autosampler. It is recommended to check the user manual of the autosampler for its operating principles and restrictions.
![Spark Alias Autosampler](/sites/default/files/styles/white_border_image/public/media/data/products/picture/controls-as-sph-alias.png?itok=2NMItzoZ)
Spark Alias Control | |
Communication interface | RS232 or LAN or USB |
Cable | Serial straight DB9F-DB9M (p/n SK02) or LAN cross cable (p/n SK08) or USB A-B cable (p/n SK06) |
