Spark Triathlon Control
The Spark Triathlon control module enables direct control of the Spark Triathlon autosamplers. The control is performed over the serial line.
Direct control means that the autosampler can be completely controlled from the Clarity environment. Instrument method controlling the sample preparation conditions will be saved in the measured chromatograms. It is recommended to check the user manual of the autosampler for its operating principles and restrictions. The chromatography station with the AS control module provides the user with access to all parameters of an injection directly from a computer and allows the user to determine the order of individual vials within sequences. Specific method can be selected for each sample in a given sequence. The method includes AS control parameters, parameters of data acquisition, integration and calculation. Straight from the software you can plan and edit the sequence table.
Spark Triathlon Control | |
