Alltech/Grace 3300 ELSD Control
Control module for the Alltech/Grace 3300 ELSD (evaporative light-scattering) detector
The Alltech/Grace 3300 ELSD Control module allows for direct control of the Alltech/Grace 3300 ELSD (evaporative light-scattering) detector. The control module allows the digital acquisition on one signal. The user can easily create the detector control method from the Method Setup - Acquisition tab, where a wide range of signal parametres may be set. All of these parameters are then saved as a part of the method and can be added as a part of the report. Control is realized via a standard LAN port using a typical LAN cable.
![Alltech 3300 ELSD](/sites/default/files/styles/white_border_image/public/media/data/products/picture/controls-det-alltech-330-elsd.png?itok=L4AD33R7)
Alltech/Grace 3300 ELSD Control | |
Controlled instruments | Alltech/Grace 3300 ELSD |
Cable | cross LAN (p/n SK08) |
