Antec DECADE II Control
The Antec DECADE II Control module allows for direct control of the Antec DECADE II, DECADE II SDC, DECADE II MD and ROXY Potentiostat electrochemical detectors. It allows the digital acquisition from all detector cells, use of the digital inputs and outputs and supports the auxiliary signals of the DECADE II detector. The user can easily create the detector control method from the Method Setup - Acquisition dialog, set the operation mode of the detector cells or create timed events in the Time table. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of each detector cell can be monitored and partly controlled from the Device Monitor window. Control is realized via a standard PC serial port using a specified serial cable.
| Antec DECADE II Control | |
| Controlled instruments | DECADE II, DECADE II SDC, DECADE II MD, ROXY Potentiostat |
| Communication interface | RS232 |
| Purchasing | LC Control - (p/n A24) |
| Cable | Serial straight DB9F-DB9M (p/n SK02) |
