Ecom Opal Control
The control module enables direct control of the Ecom OPAL Fixed Wavelength UV detector over serial line. The user can easily create the detector control method from the Method Setup - Acquisition dialog. All of the detector method parameters are then saved and can be added as a part of the report. Actual signal of the detector can be monitored and partly controlled from the Device Monitor window. Control is realized via standard PC serial port using the specified serial cable.
The control module was developed by ECOM company, any further information, including the control module manual, may be obtained from ECOM company.
Ecom Opal Control | |
Controlled instruments | Ecom OPAL Fixed vawelength UV detector |
Cable | Serial cross DB9F-DB9F (p/n SK01) |
Needed accessories | Digital Input Device (p/n DID01) |
