ESA Coulochem III
The ESA Coulochem III Control module allows for direct control of the ESA Coulochem III electrochemical detector. The control is performed via USB.
The control module allows the digital acquisition from all detector cells both in the DC mode and the Pulse mode, use of the digital inputs and outputs and supports the use of the Thermal organizer compartment. The user can easily create the detector control method from the Method Setup - Acquisition dialog, set the operation mode of the detector cells or create timed events in the Event Table. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of each detector cell can be monitored and partly controlled from the Device Monitor window.
The driver for the ESA Coulochem III detector is not signed for Windows 7, 8.1, 10 and later (but functions on those systems) and cannot be used on any 64-bit OS.
ESA Coulochem III Control | |
Communication interface | USB |
Purchasing | LC Control - (p/n A24) |
Cable | USB A-B (p/n SK06) |
