Interlab Omega
Interlab Omega
Control module for the Interlab Omega UV-VIS and Omega FLD detector
The control module enables direct control of the Interlab Omega UV-VIS and Omega FLD detector over USB.
The user can easily create the detector control method from the Method Setup - Acquisition dialog, setting different parameters based on the type of the detector. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of each detector cell can be monitored from the Device Monitor window. Control is realized via a standard USB port using USB A-B cable.
![Interlab Omega detector](/sites/default/files/styles/white_border_image/public/media/data/products/picture/controls-det-interlab-omega.png?itok=RhkDE63N)
Interlab Omega Control | |
Controlled instruments | Interlab Omega UV-VIS, Interlab Omega FLD |
Communication interface | USB |
Cable | USB A-B (p/n SK06) |
