Kontron 432 Control
The UNI Ruby Control Module with the Kontron 432 profile allows for the direct control of the Kontron 432 detector over serial line. Direct control means that the detector method parameters can be completely controlled from the Clarity environment, but as Kontron 432 does not have any means of collecting the signal using serial communication, the data have to be acquired using the A/D converter (Colibrick A/D, p/n U31, U32 or U34). Instrument method controlling the analysis conditions will be saved in the measured chromatograms. Control is realized via a standard PC serial port using a specified serial cable.
Kontron 432 Control | |
Related products | Clarity (p/n C50) Colibrick A/D Converter (p/n U31) |
Cable | DB9F-DIN5M (SK09) |
Profile | Kontron432Det.rb |
